Ditto on make sure you can flat tow an auto stick. Also not sure many know how to repair them. So I would go with a manual.
Also look for a carbureted bug, the fuel injection parts are getting harder to find. Often a fuel injection leak ends up with your bug on fire.
Before you buy one, look at parts costs. Bugs used to be cheap but now the prices have gone way up. Engines are now $500 for a core and $1000 for a used runner. Folks are asking a lot for running bugs now.
Now Covairs are still dirt cheap.
Bugs haven't been cheap for 10+ years. You can still find good deals. There is good info online about adjustment and repair of auto stick transmissions.
Here is what they actually are:
The Autostick transmission combined a torque converter (which lets the engine run while in gear so you can drive the Beetle like it has an fully automatic transmission), paired with a 3 speed standard transmission that uses a vacuum-operated clutch to shift between gears without manually depressing a clutch pedal.
Pushing down on the shifter triggers a momentary switch(?) which actuates the clutch, so you press down, shift and let go. You can't rest your hand on the shifter like some people do with manual transmissions, since that's like keeping your left foot pressed down a clutch pedal.
Fuel injected ones are very fairly rare so avoiding those isn't hard. It was only on them for the last 2 or 3 years when sales were probably way down.
I tried driving an old manual transmission pickup once and got it stalled out several times then it wouldn't restart. The owner finally got it going again. I was like ok yeah I don't like manual transmission.
Autosticks just need a bit of knowledge to keep adjusted and working. There is way more online info now than 10 years ago in terms of video tutorials on YouTube. Just now looking on there, there is a video from 2 months ago on diagnosing the vacuum clutch setup. It's a small but dedicated following.
