Buying 85 IDI ATS turbo motorhome!
gnathv
Athens, Al
Your cdr is set up a little differently. You should be able to look from front through hood to see the bottom of the air box. Mine had a single bolt that held the lower housing secure, remove that bolt, the hose to cdr and twist and wiggle the housing off the turbo, there’s an o ring that seals housing to turbo air inlet. Obviously not a lot of room in there.
gnathv
Athens, Al
Sorry I thought you were asking about airbox.
The sensor looks like your pyro thermos couple.
Cubey
Van dweller
USA
I see no CDR on the 085:
The 088 has it, attached to the airbox lid, connected to a hose to the valve cover. Note how the valve cover connection on the 085 goes to the airbox base. The 085 sucks unfiltered air, the 088 filters it.
I have seen many 085 air boxes online with a CDR attached to the airbox crankcase vent connection but according to the diagram and my setup, ATS didn't intend for there to be one.
Yep, that's what it is.
Cubey
Van dweller
USA
The $39 NOS K&N arrived today.
Cubey
Van dweller
USA
The driver's side battery tray was basically gone. The wheel well isn't fully rusted through, its still pretty sturdy. Once its warmer, I'll go back and spray in some commercial grade rustoleum in there.
I had to drill new holes but there it is, new plastic battery tray. The other side is about 1/4 gone but still currently useable. I might just go ahead and replace it too though.
Cubey
Van dweller
USA
I got a few things done today it needed.
First was an oil change. Heck knows when it last had one. The oil seemed filthly, even for an IDI. It had a basic Purlator filter. Now it has an FL-1995 and a belly full of Valvoline Premium Blue 15w40.
Next was fixing a missing leaf spring clip/clamp. I had new cheap LT HT tires put on yesterday and I noticed the missing bit. I had to grind and hammer the square U bolt to get it on, due to the leafs not being perfectly aligned. But finally I got it on. They aligned better when it was tightened down.
Then I moved on to the fuel filter. I haven't had any idle stalls since I have run a fair amount of diesel additive and fresh fuel, so I skipped a transmission fluid fuel system cleaning. The old filter was a Wix but less large than the new Motorcraft filter. The old is rusty on top!
Finally, I put this in. I've had it 2 years in other setups and it's been great. It's wired to the house battery system.
Cubey
Van dweller
USA
Cubey
Van dweller
USA
How fun! I need to do injector o rings. Ive known for a week or two but now I'm finally tired of a daily morning stall after 5 seconds of running, then 3-4 rounds of 10 second cranking. I can see several wet caps, so yeah. I'm going to do it Wednesday. I have to reach in and against exhaust pipes for the turbo, so it needs to sit overnight before I can get to the passenger side ones. I have stuff I have to do tomorrow, so that's out.
Autozone won the "bidding war" for lowest priced kit they could have by tomorrow at around $39 with tax. Oreilly is about $57+tax and Advance was $80 something.
I already had orings and I tried to source just the hose, but couldn't locally, so a complete kit it is.
I did my F250's 2 years ago with an Oreilly bwd kit and it has held up, though i used different orings i bought online. I still have the orings from that kit. I guess it doesn't hurt to have spares.
It should be interesting trying to do this on a van. As i recall, I had to loosen the injection lines at the pump to move them to line them back up on the truck. I don't know how possible that's going to be on this. Hopefully i don't have to pull the turbo and all that mess.
tke395
