Cat 3126 motorhome......IT'S ALIVE!!!!
Definitely a " new world" when dealing with dual voltage machines
I am seeing actual 12v compressor fridges, hmmmm
3 way fridges are super nice, but can be expensive. I wish my camper still had its 3 way in it, but someone took it out before I got it.... They work great with a small solar array and battery setup, so you don't use propane all the time.
Clb
Another old truck
nannyfornia
There's a new offering for 12v only according to the net
Cliffnotes version:
The generator was putting out 157VAC.... uhhhhh...... voltage regulator was bad, i was able to steal the regulator off of another onan generator..... all is well now.
I let the generator power the coach for about an hour with no issues, AC running the whole time...... other than the horrible smell of propane engine exhaust in my carport, it was legit..... hardly moved the needle on the LP gas tank..... good times.....
Im calling it.....SHES READY FOR THE ROAD!!! So when the Lord absolutely lays down the plan for getting us outta here, we are ready......Joshua ch 3 and 4.....
On today's episode of "who's smarter than a 25yr old motorhome"..... Jesus Freak finds his batteries are dead AND he has a REALLY weird electrical issue....... que theme music...... take a load off fan*y.... take a load for free..... take a load off fan*y.....and...and... annnnnd....ya put the load right on meeee.....
So, I haven't crunk the coach up in a few days...... and we got some clear weather and I was gonna check something out, but the battery was dead.....well, mostly dead.....so I hit it with the jump box..... ran a while and died a minute or so after I took the jumper off it......oh no...not this again.... ultimately, it needed more charge.... but i got it running....happy.....good.....THEN..... it wouldn't turn OFF!!!!!.... oh no you ditnt..... but i don't mean you turn the key off, everything deenergizes, but the engine keeps going...... that would be easy, tedious and a bit pricey, but easy...... nooooo, I cant have "easy"..... I mean, you turn the key to the off position and NOTHING happens.....like, the dash is illuminated, i can hear the ABS pump going, AC is blowing, engine purring......like Twilight Zone......
It took me a couple hours to track this down.....but here's the Cliffnotes version followed by a question to those that might know.....
At first, I traced it to this solinoid.....(possibly the diode)having gotten stuck and feeding the "key on" side of these relays.....
I actually took the solinoid apart and cleaned it, it was just fine.... but purely by the inspiration of God.... i happened to notice the way the ABS key on relay was responding as I was reattaching the solinoid...... so get this.... theres a short in my ABS unit that is feeding back to the "key on" relays...... so if I leave this wire detached...... everything acts normal.....
So here's the question......
How important is it?..... can I just wire in a switch that I can turn on after I crank up the coach?..... do I "need" to fix this.....? Whaddaya think?....ABS units cost money.....its not a daily driver...... will I not have brakes?
Clb
Another old truck
nannyfornia
How far out there is this thought....
Abs=antilock x x
How possible is it to lock them up on said chassis?
In snow yes, but...
However, if it's a canbus situation then you can't delete it with a switch..
I've seen that issue before, but I don't know what you can do to fix the a.b.module.
Fun fun fun
Abs=antilock x x
In snow yes, but...
Fun fun fun
That's kinda my thought really...... I don't drive fast..... and i actually pulse my brake pedal like they taught you to stop in the 60s, i dont just stand on a brake pedal like kids today, and i can stop my dually on a dime...... as well as I have an engine brake on this thing......
I just went out and unplugged all the connectors on the ABS unit and it still doing the same thing..... there's 3-4 relays associated with the brake system...... i gave them all "firm taps" and got nothing..... Monday ill unplug relay after relay systematically and see if i can narrow it a bit more, but I believe the ABS block itself is okay as well as the electric brake booster motor....... we'll see..... unless someone pops up with the answer before then....
Alright.....I found it.... there was some corrosion in this connector that was conductive...... gave it o wiggle and some contact cleaner spray.... its good...
Clb
Another old truck
nannyfornia
Oh
My
Gooooooooodness
Are you still working on the space shuttle? :frustrate
Looking at those what 5 separate connections....
At least tell me the are factory labeled....
Runs away screaming
Oh
My
Gooooooooodness
Runs away screaming
Believe it or not..... all the white wires all over the coach are actually labeled every 10-12in for what they are for..... it is incredibly helpful......
.....space shuttle.... it ain't that bad......lol
Clb
Another old truck
nannyfornia
That's not a bad deal...
Labels are great for trouble shooting.
As long as nobody hack fabs the harness.
Keep on it. :cool:
PelliX
Enschede
I always knew you had a screw (or bolt) loose, JF... ;) Lookin' good mate, just keep her on the road and don't forget to smack the little cymbal from time to time.
There you have it senor @PelliX , proof the cymbal got mounted in the motorhome.... theres a pair of chop sticks to the left of the diver seat for whacking it!......
19Eighty-Sixed
