Well I have done ALL the above, replaced pads, replace booster, replace RABS valve, adjusted rear brakes etc... dadadad... I had a friend of mine, VERY KNOWLEDGABLE, I might add. He told me there was service bullitin from FORD stating that when the front calipers ( BTW, I replaced those as well) are replaced, rebuilt whatever, the original master cylinder does noes pump enough fluid to aal four brakes, therefore causes the mastercylinder to fade down. I fought with this for a year. Finally, I did what my friend said and ALSO what the service bullitin said to do. Install a mastercylinder from an F450. I got one from AUTOZONE for a 96, I believe they are the same for several years. Now if you dont buy the booster also ( as recommended ) then you will have to elongate the mount holes on the mastercylinder to fit it your booster, that will be the only modification need, everything else ghooks up the same.
Now when I did this, someone here told me that was not the right way to fix it, they said, I did not fix the problem, I eliminated it. OK its fixed. Then someone found the service bullitin and posted and it said the same thing.
I'm sure if you do a search you can find it, but its been awhile, 1 year I think, and the brakes are still working great. I did not change the booster, I wish I would have just for piece of mind, but as I said they are fine now and dont fade down. Good Luck with it and let me know if you have any further questions
