bucholzi
I'm messing around with my brakes since I have sinking pedal, but I cannot pinpoint the problem.. I got plenty of brakes, but when the motor is running and I pump the pedal and holds firm pressure, the pedal sinks slowly. It does not sink all the way to the floor, but almost, and I never loose brake pressure. When the engine is off I get solid pedal with absolutely no sinking.
I have bled out the entire system (including the RABS). I have new braided hoses, new pads, new rotors, new drum cylinder and new shoes. Rear brakes adjusted to slight drag.
I have tried to pull the spring from the RABS, still the problem persist. This should indicate that the RABS is not the problem
When I run the engine and the pedal sinks, the level in the master cylinder reservoir remains the same: does this indicate bad MC I don't have a plug that fits the master cylinder, so I haven't tried to plug the ports to check for intern leakage.
But I got a vacuum gauge in the truck, and if I pump 2-3 times the vacuum drops low (down to 5 psi) and as the vacuum builds up again to 20-25 psi the, the brake pedal sinks. And it seem to stop as the vacuum stabilizes. Can it be the brake booster working harder as the vacuum increases
I seem to recall somewhere that this sinking pedal is normal behavior for these trucks, but that ford came with a alternative master cylinder (not as a recall, but to make the complainers happy) that removed the symptom? Any truth in this, or is my memory playing tricks with me?
