Body mount Q
slicknic
Mission, BC
I am doing a 90's front clip swap on my 84 and the front body mount bolts are seized. I was wondering if anyone knew what size bolts I need to replace the stock ones. Reason for the questions is that I am planning on finishing the swap tonight after work and the stores around here will be closed so it would be nice to already have the bolts. I am replacing the front 2 mounts by the rad support
I haven't met a pair of them yet that didn't need a torch to convince them to come out. :rolleyes: Might sound dumb, but get yourself a couple lenghts of all-thread in different diamters, and make your own. Once you have done that, you can go back later and replace them with the correct hardness.
slicknic
Mission, BC
ya thats what ill probably do. I guess I was kinda hoping someone off the top of there head would know that its a 1/2" course 5" long or something like that :)
RLDSL
Diesel fuel abuser
Arkansas
Mr.Sawzall is your friend :D
You mentioned replacing the front ones at the radiator support, but you'd best change them all at once, the rest will be hammered as well.
I wound up making some up with threaded rod too. Works great.
----------Robert
