The_Josh_Bear
Ok now we are getting somewhere! Having zero flow out of the IP(while running) means for certain you have zero flow INTO the IP, or its junk.
These IP's are a flow-through design, the extra fuel cools them down and the housing pressure differential is used to control the timing. No fuel coming out screws up the pressure differential, if nothing else. There is a minimum spec for idle flow rate but I can't find it in all my Googling... psi is different than flow.
Does anyone know the idle flow rate Ford/International calls for on the IDI? I know the max rate at 0psi is about 32gph. (I feel like it's 1 liter in 30 seconds but I can't confirm.)
Also what I can't remember is if the schrader valve is pre filter or post filter...I feel like it was pre filter which doesn't tell you how much flow is getting to the IP.
At this point I'd be removing the line to the IP and checking flow rate through that with the e-pump. See how much is making it through the filter. Also there's an inlet screen on the IP inlet, get a mirror and check that out for debris while you're at it.
@IDIBRONCO has you covered on the fuel drain back issue in post #12. The best way to confirm it's happening is to just pull the filter in the morning. If it's half full you've got fuel drain back. If it's all the way full, you don't.
