Beans OBS E-fuel done
fordtuff
arkansas
Wasn't too bad of a job. I still have some tiding up to do before i call it all done.
fordtuff
arkansas
Well, the system has defiantly improved the drivability.seems to need one more revolution to crank. All in all I like it .. If I can get the pump to quieten down some ill love it.
fordtuff
arkansas
Had to drill two holes on the bottom flange of the frame rail.everything else fit right up.it goes a lot smoother if you remove the down pipe and turbo intake on the motor side for the rear fittings,then take the bolts out of the tank selector while dealing with the factory quick connects.
oregon96psd
Kuna, ID
ok, Ive been really eyeballing this kit for awhile. I know it can be built cheaper, but I didnt really want to screw around gathering all the parts...kits are nice like that lol.
fordtuff
arkansas
After running it a week now I see I'm going to make some changes in it. Follow me here a moment. The package comes as a drop in to use the selector valve for both tanks and that 044 Bosch is a near monster which I believe is a problem. The noise I'm hearing ( I believe ) is some cavatation. The way the pump is mounted vertically, and pre and post filters on either side there are four 90 deg fittings and one on the selector valve and probably one on the tank.that to me is a lot of restrictions. I'm thinking getting a longer metal frame mount and laying the pump horizontal and eliminateing all four 90's thus reducing the restrictions.
fordtuff
arkansas
And maybe a baffled 91 gal never used rds tank under my toolbox and just do away with the selector valve altogether .. )
If I didn't have a flatbed, that's what I'd do. Think I may end up with a smaller medium duty tank or something.
Lance
