david_lee
"Length of the Cable between the Battery Posts is is 62.5 inches in Length, and is 2/0 gauge Cable. The Length of the Cable from the Battery Terminal to the 3/8 Lug Terminal is 52.5 inches in Length. The Accessory Lead is 22 inches Long and is 6 gauge in size with a 5/16 Ring Terminal Attached."
i found this description of a new factory type battery-to-battery-to-starter cable, and the lenghts seem a little off to me. i am making this comparison by memory, but from what i could tell with the battery and starter cables still on the truck; the battery-to-battery cable is shorter than the battery-to-starter cable.
my question is directed to those that have replace thier cable sets: is this description correct?
i have converted to studded batteries, and while replacing the cable ends with lugs, i found that there was a lot of corrosion on the inside of the factory cable jackets.
i am planning to purchase some lengths of wire to replace the factory crap that is still in the truck. i found the above description while trying to locate some info on how much wire to get. i am planning to get 4/0 cable to go from battery-to-starter and 2/0 cable to go from battery to battery, and get both in SAE J1127, Type SGT rating which is acid, oil, moisture & corrosion resistant and good to 105C (221F). sound good?
if these measurements are correct then it would save me some time in having to remove the starter cable to measure it
sorry its a bit long winded
