rancherman84
P.E.R.F.E.C.T!
the truck my turbo came out of has the gauges,but the pyro did not work.
is there a way to test the pyro to see if it works?ohm's reading or somthing?
i'd hate to lose the motor because of a false reading,not to mention what a PITA it would be to change after its in the truck.
also is all that heat shielding on the down pipe and firewall still avalible?,if so do you really need it?
