Bad coolant leak for a few minutes during cold mornings
Cubey
Van dweller
USA
I was parked slightly downhill last night at a rest area. I saw no moisture on the ground this morning, no seepage from the lower hose, and no spray on the engine presumably, I heard no squealing when I promptly got on I-10. So hopefully that's solved.
WrenchWhore
Lake Havasu City
Judging by how porous, pitted, and corroded i've seen these upper and lower coolant elbows get, i'm not surprised you're seeing a slight coolant leak from that. Before I installed this last engine I wire wheeled the heck out of both upper and lower. It was a combo of this white/greenish powder, corrosion, and rust. Even after cleaing it wasn't pretty or perfect. I used worm clamps since it seemed like the only thing that would be tight enough to seal. If the joint was super smooth like a plastic formed radiator outlet and didn't corrode I could see the constant clamps working.
The old style worm clamps work fine, I have them all over my vehicles. But if you install new hoses under the clamp, guaranteed you will have to snug them down after they get some miles on them.
sramasya
