Won’t restart after sitting for 30 minutes
Oldiron
Windsor, CO
Yup, This is definitely the problem. I had multiple chances this last weekend to test the theory. Colder the water the quicker she'd fire up. Does anyone know what the actual failure is? I'm assuming I need to replace the IP?
These are the three vendors that ae recommended
for IP, Injectors and other goodies.
Black dawg
sw mt
The problem is wear in the advance piston bore. I have found that putting power to the cold advance solenoid (causing the piston to move to a different spot) most of the time will get one starting when having "heat soak" problems.
Oiler
