adamsanders
Hello everybody, I’ve done quite a bit of searching on this but haven’t found too much info, especially with photos. I am wanting to add some additional lights to my truck as well as the headlight relay mod and maybe some other fun electrical projects down the road. I really prefer things to look as clean as possible so I bought an auxiliary “marine” style fuse block to keep all of this new wiring together and off of the battery cables/terminals. Thing is, I cannot figure out where to put it. I’ll be using several relays too. The only logical place I see as a possibility is on the passenger wheel well but my voltage regulator and low vacuum switch are located there so I’ll have to work around that. I thought about maybe behind the seat in the cab (single cab) but I’m not sure there are good wire ways out of the cab back there without drilling. I’m sure you guys have encountered this and I’m just looking for ideas, thanks.
