ANY INFO MUCH APPRECIATED!
gingrass179
phoenix, az
Hey guys i havent done my signature yet but i have a 90 ford f250 with 7.3 and 5spd it hasa holley red fuel pump and rebuilt injection pump and rebuilt front end
Anyway i just got a turbo set up for $200 it is a garret a/r. 70 and has the intake box 2.25" dp and y collector i believe it has a wastegate?! Looks like it it has some actuator?! And i think it has oil return and pickup
Mainly wondering if anyone knows where to get the upgrade kit for the turbo? Bigger a/r and bigger dp?
Any other items i need i think i need passenger valve cover but i dont know about exhaust manifolds or anything else
Or am i wasting my time and should i just rebuild the turbo i have any ifo muxh appreciated
typ4
Newberg,OR
You dont need a bigger a/r, and ATS doesnt support the system anymore, so do some searching on here and you will find how to mod the elbow.
I do turbo mods during rebuild so can help there. Involves machining the comp housing for a larger wheel.
gingrass179
phoenix, az
So do you do machining and rebuild for these? I have cash and am just excited to get this project underway if so how much
tractorman86
Buckeye, AZ
It sounds like you have an 093 ats (factory turbo from a 94) russ definitely knows his stuff. So you are in phoenix, if you want to use someone local there is one shop I know is pretty good, I just can't comment on his pricing
gingrass179
phoenix, az
Well i dont believe it is a factory one cayse it has the ats airbox and notthe one that said ford
gingrass179
phoenix, az
And what do you mean mod the elbow im no noob to a wrench but the only diesel experience i have is military so just r and r there but have done quite a few gasser builds i just want whatever i can get out of this thing and ive heard about the ats upgrades on there housingand it seems like a good set up
typ4
Newberg,OR
Check jamoos thread about modding the outlet elbow.
I am going to quote the turbo rebuild and upgrade high because the last 4 have all been damaged beyond repair and it is cheaper/less labor to do a new chra . so
For the 60 -1 wheel upgrade and all new center section it runs about 460.00 machining included.
gingrass179
phoenix, az
That doesnt seem horrible is the mod worth it im mainly in it for mpg so i want to flow decent. Or is the ine i got but rebuilt more just what id want cause right now n/a im getting 22 @65 and 2050-2100
'94IDITurbo7.3
HAMMER DOWN!
Fowlerville Michigan
so is that pretty much $460 for a new turbo?
that pricce does not seem bad at all.
