Another what is it?
Selahdoor
Index Wa
What is this thing?
It's an "L" shaped thing, plugged into the harness, but just laying there between the heater hose and the fuel filter housing...
It has no holes. Nor attachment points. Nor anything that looks like it could have been plugged into something else.
chillman88
Central NY
It's an amplifier of sorts for the Water in Fuel light. Don't ask me more than that because that's all I know lol.
chillman88
Central NY
Thank you. :)
You're welcome! I only know because I asked on here a couple years ago!
I just yanked mine out since I don't have a water in fuel sensor anymore. I slimmed my harness down when I reworked my glow plug harness.
Selahdoor
Index Wa
Just did some research.
That little "L" shaped piece of plastic costs 80 bucks??? :eek:
RDieselKid84
Mississippi
That's the water in fuel light relay, I just bought one from my Ford dealership. It was $60.00, I'm going to wire it to my new fuel filters on the frame. I'm moving them from the fire wall and had to use this relay to replace the one in the filter to get the light on the dash to work.
Cainon
Smithfield
Could this be the cause as to why my water in fuel light never goes off? It stays on 100%. I've done the diesel additives, drained separator, quality fuel... at another :frustrate moment.
chillman88
Central NY
Try unplugging it and see if that makes it go out. Could simply be a bad sensor?
Where is your sensor located? The 6.9 had a completely different separator setup than the 7.3 and most people bypass the water separator because they are a very common leak point.
Cainon
Smithfield
I would bypass it if I knew how. I've read how to do it just scared to screw something up until I learn all the code language going on in the bypass post. Still learning what's what.
Cainon
Smithfield
I think this is it from a post I read yesterday
720Diesel
