Thatoneguy
So I just got new batteries in the old girl about a week ago. But apparently I had a parasotic draw happening. So I disconnected both grounds on the batteries, and tested amperage with the multimeter and it showed it was drawing about .14 amps. I pulled each fuse on the truck and watched to see if the draw went away. None of them did it so next I started thinking a their is a short somewhere. Can't find anything. Here's the kicker........... When the AC switch is on, and I touch a ground to a ground terminal, the AC pulley locks up. If the switch is off and I touch a ground caple to it's terminal, nothing happens. Is this supposed to happen?! Could this be my parasotic draw?
Sent from my Moto Z (2) using Tapatalk
