advice on steering...
Greenbeast6.9
grease monkey
Tennessee
OK here's the deal, my steering has been rigged for 7 years now now the other day i bent the steering arm causing death wobble!! I am thinking that i need a drop pit-man arm and i could adjust the steering in.( after i but a new steering arm. My problem is that both arm rub on my leaf springs at full turn and this is causing problems( i swapped a 77 d-44 in 7 years ago to make it a 4x4)
Now remember this was 7 years ago i was 17 and had no money, so it is a little cobbed!:D
it migh be a little hard to see in these pics i will see if i can find some more but the pitman arm that is on there is straight out. so does anyone have a drop pitman laying around?
Mr_Roboto
Elyria, near Cleveland Ohio
I might still have one I bought for an 82 F250 years ago. I didn't have a big enough socket to change it then, and then I totaled the truck. I'll check later, if I have it it will be in a storage trailer across town.
subway
be nice to the admin :D
York PA
cant see your steering set up well enough to tell if you geometry looks out. death wobble sucks, been there, crapped my pants at that.:eek: if your arm is as steep as you say it is i would think bump steer would be an issue.
death wobble can be hard to track, especially with a custom set up, good luck.;Sweet
so on a side note, how has the dana 44 held up over the years? dousent look like you trussed it at all for the weight of the truck.
Greenbeast6.9
grease monkey
Tennessee
:confused:
really dumb question....
you're not using the same steering linkage setup from the IFS axles are you?
Its not a dumb question, because i have used the ifs steering since the axle was put in. Do you have any other ideas for me that i could use?
Greenbeast6.9
grease monkey
Tennessee
so on a side note, how has the Dana 44 held up over the years? doesn't look like you trussed it at all for the weight of the truck.
I have had an axle shaft break but other than that no issues, But after my pull yesterday i think i fubard the R&P or the transfer case.-cuss Oh well it was worth the fun!:D
:confused:
I'd start with getting a setup off a f350 with a solid dana 60 axle. Your steering geometry issues will be solved immeadiately as well as bump steer issues. If the tie rod studs are of different diameter, take a look at a chevy setup, dana 44s were found under chevys for many years.
