Ah-ha!
So your tube is smaller?
Just so that you know, yesterday my pop valve went off
and just before that happened, my A/C started cooling better at low rpms and speeds than at highway speeds. Methinks that my VOV is malfunctioning so I guess I'll have to postpone my move to Houston till later...
I was going to move tomorrow... Oh well...
I'm going to yank that VOV out and check for debris. I used a Autozone compressor, so that might have something to do with the VOV, but on the other hand, if the compressor can produce high enough pressures, I don't think the 'pressor is bad. Just the same, I'm going to be looking for debris and flush everything. I will take the condenser out and lay it down when I flush... I just might use that DEC 46 PAG oil.
Oh well, I'll start on it tomorrow...
Oh yeah, since the red orifice tube (.062") is smaller than the original blue orifice tube (.067") and the blue orifice tube is same size as the VOV (when fully open) that is rated for use in less than +105 degree temps, would I be correct to say that R-290 requires a slightly smaller opening?
I wish I could use an adjustable expansion valve, but it's way too much work to convert our systems to TXV...
