Learned a little nugget of wisdom on my own and thought I'd give a little back. I'm sure this is old hat to most of you, but I missed it.
So I've had my truck about 5 years now, and have gone through most of the common issues- batteries, cables, glow plugs, return lines, etc. I've also gone through 3 or 4 starters. Through all this I've noticed how crucial crank speed is to happy starting.
Recently I had a starter go up in smoke thanks to a stuck solenoid, tools locked in the garage, and not enough coffee that morning. When I replaced the starter I had great crank speed, but not long after it slowed. A lot. Checked batteries, cables, blah blah blah before I narrowed it down to a defective starter. Yay Napa.
Well, I do some research to find a better starter, and learned that the gear reduction starters and straight drive starters are directly interchangeable. My truck came with a straight starter, so I replaced it with the same every time. Until now. Holy crap does my truck start great now. 29* the other morning, no plug, fired quick as ever.
So if you have a grumpy starting truck, or need a starter, definitely get a gear reduction unit if you don't already have one. One of the best repairs I've ever done.
**Cliff Notes**
Gear reduction starters rock. Bolt in swap from straight drive. Don't be dumb like me and replace a straight drive unit, ever.
**Cliff Notes**
