I'm not saying your shops are not reputable, I'm saying that MEL is known as a premiere builder of pumps, thus knowing what you have gone through and such would no doubt make absolutely sure that what you got was a great pump!
The objective is here to resolve this issue you have nothing more, we want to see you with a good working truck regardless of where parts come from.
No, I hear ya, and I appreciate the help. I had assumed the shop and suppliers were reputable, because I was referred to them by lots of people in my area. Not only that, but we tried multiple suppliers/rebuilders. I know Mel is a great guy and a great builder of pumps, I don't dispute that at all.
I do have my doubts that so many shops are bad, though. There are many of the IDIs on the road down here, still, and I just find it hard to believe that going through so many pumps and suppliers, that none of them can get it right. But, it sure does appear that may be the case! I just keep thinking that there must be something else going on here.
Seems to me with what you have said about new lines, filters, and such and not dropping tanks, that before anything more take place you should check your tanks for contamination prior to any further diagnostic steps.
We did drop the tanks, but we didn't clean them out, cause there were no signs of contamination (plugged filters, dirty fuel, starting problems, etc)
I should also mention that my old IP did not have this issue, and it was on the truck since it rolled out of the factory! It was showing signs of wear, and my injectors were overdue for a change, that's why we changed everything. But the old IP never had a hot starting issue. And I've never had any other indication of dirty tanks/fuel. I'm not saying the tanks are clean, but I don't have any other symptoms of dirty tanks.
I think it would take some time with an IP running in the truck for the heat soak issue to be cause by a dirty system. We literally would drop a IP into the truck, run the truck until it was warm, then turned it off, let it set for 30 minutes, and then it wouldn't start. I'm no expert, but I would think that it would take more than 15-20 minutes of running the truck before dirt was an issue with the IP. And really, if the filters are never dirty and I'm not having any other symptoms of that, how likely is it that dirt caused this problem on 6 different pumps (most of them in the truck for less than an hour)?
I surely hope you get your unit running well and soon cause I know what a pain in the backside hard hot starts can be as I get them NOW and then.
yeah, me too. I really am at a loss as to what to try next.
Oh and DON"T use FRAM filters get some Motorcraft fuel filters if possible, what kind are you using btw?
I've got a wix in there right now.
