94 idiT , valley pan gromment
Jritchie
Tucson
I'm rebuilding my engine, I can't seem to find the rubber grommet that sits in the valley pan from the turbo pedestal that the oil drains through, the one I one I got in kit is for the cdr (I think that's what it is called, for crank case ventilation) on the non turbo that's sits back there, it's 1 1/2 inch inside diameter, and the turbo drain is 1outside diameter. Any advice will help
gnathv
Athens, Al
Try Russ type 4 on this forum or check a dorman 42344 pvc grommet. I’ve seen those used.
Welcome to the forum. Russ who's sign on name is typ4 has what you need. As a suggestion use a quality rtv on this rubber fitting. Its never going to be seen where it sits. I fill the grommet where it fits in the valley pan. I also use rtv on the turbo oil drain back tube where it fits into this grommet. I apply it low on the tube so when I install it the rtv gets a tight fit to the rubber grommet. No leaks ever.
