just performed a compression test on a 94 idit that i pulled out couple of weeks ago, and i got 200 psi roughly across the board + or - 10 psi, tried it wet and got about 20 more on each cylinder. is that acceptable? the motor started withing 1/2 a turn and that was sitting all winter, smoked like it was on fire, but pop tested the injectors and they poped at 12-1500 psi and they all had a garden hose spray pattern. nice solid stream. all the injectors where stamped 1993 year. I'm not sure the history of the motor, but kinda figured it sat for a while, the truck had a busted front axle, and it was a plow truck. the truck also had about 240 km's on it.
thankyou
thankyou
