Ft Wayne clutch has a great deal on a rebuilt clutch setup that the disc is lined with 100% kevlar and it is matched up with a pressure plate that is actually fairly lightweight which is REALLY nice. the kevlar has so much higher coefficient of friction that it doesnt require a pressure plate with springs that need two men and a boy to push the dang pedal down, quite the opposite, the stuff grabs so well that they can match it up to a light sprung pressure plate and it will still grab and pull insanely heavy loads without any trouble. I have about the worst kind of arthritic condition and if it weren't for that clutch I would have had to put a slushbox in
They call that thing their Hustler clutch. If you are going for a SMF setup, get a 12 1/4" it will cost a bit more but you get more friction surface and you also get about twice as many springs in the center hub as you do with the 11" and rollover noise is close to non existant, you basically have about the same spring isolation that the DMF gave you without it's drawbacks. I regularly gross 18k and better up to around 22k and that kevlar clutch setup works sweet ( my first 11" kevlar clutch outlasted the DMF that it was up against and the DMF folded, this is when I found out the hard way that you don't match anything stouter than a stock clutch up against a DMF, or the overload protection section on the DMF becomes the weak link in the chain. The flywheel folded after 50k miles of being hooked to that clutch, but the clutch still measured out as new and lives on in another member's truck) It's always a pleasure talking with the folks at Ft wayne Clutch when You have a question because you actually get to speak with the guys who put the things together.
You don't want any kind of clutch with ceramics or metal in them. Those are great for pulling sleds, but not real great for longevity
