xekon
So my 1993 Ford 7.3 IDI 4x4 with the E4OD has been sitting for 3 years, it has been sitting because it needed a new transmission, BUT before sitting it Started up easy and Ran great!
I found a parts truck for $500 with a good E4OD, I got the new transmission installed.
Soooooooo, tried firing her up, no go, checked schrader valve, got fuel there, unscrewed all 8 hard lines from the top of the injectors, no fuel out of any of them.
With key in On position I have 12volts at the Fuel Shutoff Solenoid, and I can remove and hook it back up while the key is still on and I hear and feel the click it makes each time, so im assuming if you hear it click, then its working.
I tried removing the fuel filter, and adding a can of SeaFoam, but then I was cranking every couple of hours to get it into the Injection Pump.... not realizing that it was going out the return line.... So I might have to try that again and crank it just enough to get it into the Injection Pump and then let it sit....
I removed the fuel return line from the top of the injector pump, and fuel comes out of there steadily when I am cranking.
Was just wondering if there is anything else I can do, like taking the Injection Pump apart and cleaning something? or possibly using compressed air at one of the fitting on the pump to break through?
