freebird01
Post Turtle!
87 samurai
1.3L carbed w/ factory a/c that still works
3" lift springs SPOA
almost new 33" dunlop mud rovers
1" aluminum wheel spacers.
trail tough double tough front axle shafts
5.38 gears
front and rear lockers
breeze cross over steering w/ factory tie rod
4 wheel disc brakes
spidertrax tcase ebrake
spidertrax panhard bar
diff caps on both axles
4:1 tcase
was a light roll over so body is not perfect. ive gotten most of it straight again. replaced the windshield frame, front clip, targa, factory roll bar.
has a set of trail tough flares that will come with it that have cracks and pulled out screws in the rollover. can still be made to work. still needs rear shocks and a new windshield glass.
will need a new top since it has some rips in it from the roll.
runs and drives just fine.
front clip used to replace was rusty. i have cut out all the rust and welded in new metal as well as doing a virtual lift. rear wheel well has rust and is a good canidate for the virtual lift as well.
I began to cut out the rocker panels and build some heavy duty rock sliders out of 4x4x3/16" sq steel that will be attached to the frame. one side is 90% complete. just need the brackets welded to the frame and some holes drilled and bolted on. (will be done before sold)
also will come with an almost flawless set of dodge neon seats.
i will also be installing a new windshield before it goes..
lookin for $2800 or would trade for the right truck or bronco
http://bbs.zuwharrie.com/content/topic,112964.0.html
5.38 gears
4 wheel disc brakes
4:1 tcase
