160k87F250
not rocket science
87 F250 Supercab XLT Lariet, White w/ tan cloth interior, 6.9, C6, 3.54 limited slip. AC, P/S, P/B, power windows, power locks. Bucket seats and console, bedliner.
I've owned this truck since Feb 1999 when it had 125000 miles on it and it now has 174500. There has been lots of repairs and upgrades on this truck and is very reliable. I would not hesitate to take it anywhere is the USA. Made it to the rally and back without a hitch (Joe, can you say that? , J/K) It's Pa inspected and ready to go. Here is a short list of whats been done to it.
1/2007: New ft pads, ft rotors, r/s caliper, rear shoes.
9/2006: New starter
6/2006: New drag link, alignment, heater control valve, fuel filter.
4/2006: New flow master muffer, TCI aluminum deep transmission pan.
12/2005: New brake hose. LF
10/2005: Banks pyrometer installed.
5/2005: New brake hose RF
5/2005: Custom exhaust, 3" y-pipe, 2 1/2 tailpipes w/ 3.5" stainless tips.
4/2005: New glow plugs and controller.
2/2005: New fan belts.
1/2005: New Injector pump, return line kit, wiper transmissions.
1/2005: New trans valve, trans vacuum diaphram, ignition lock cylinder,
3/2004: New vacuum pump.
10/2003: New radiator core support bushings.
6/2003: New front springs, steering stabilizer. front shocks. 11/2002: New heater core. Steering coupler,
6/2002: New neutral safety switch.
1/2001: New rear tank sending unit.
3/2000: L/R parking brake cable, L/F power window motor.
1/2000: New oil cooler O rings
1/2000: R/s parking brake cable.
1/2000: Rear shocks.
12/1999: New water pump.
3/1999: New lift pump.
Thats what I have reciepts for. I've changed the oil every 3000 miles, flushed cooling system every 1-2 years. I have also installed Transfer Flow fuel filler necks to aid in speedy fill ups. That was done in 2000 or 2001. See my sig for what else is installed. Its in good shape for the years. A little bit of rust is starting to poke through. I've had the interior out and sprayed bedliner material on the floorboards.
$3200.00 or best offer. I can send pictures. It will take me a few days. Thanks for looking.
John
9/2006: New starter
John
