87 Crew Cab w/ 6 doors
Stupid little things, they need to be done too
3Kp
Indiana
If I'm see this correctly your bumper is not bolted on it's welded on? What it the thickness of the metal?
its bolted on.
using the 2 bolts per frame rail.
i have some 1/2" plate thats welded to the RSK cross member to hold the winch.
this bolts to 2 x 2 x 1/4" thats welded to the front of the main bumper brackets.
there will be more braces added to bolt to the front of the frame rail if needed.
3/16" diamond plate.
i was going to put a light bar in the center, but no way to do it cleanly.
will be adding it on somewhere.
chain storage and a cleaner disengage lever in the works.
oah how i loathe body work
so instead of repairing my rear, rear CC doors,
it was a glorious/sad moment.,
bought the doors from a craigslist burning man hippy.
45 bucks each!
super straight!
COMPLETE!
the sad:
this guy cut up a 90 F350 2wd CC LB 7.3 for an art car he called the snuggle wagon.
but he said he did have an attachment for a stripper pole ontop of the engine... lol
but boy did he cut the hell out of it.
his welds made me cringe, and think, "are you snuggling for protection"?
ill be putting these on the bronco, and stealing the blue doors for the 6 door.
so i wont have to paint the jams.
subway
be nice to the admin :D
York PA
I kinda want to see the snuggle wagon now! LOL
twins at home, mama expected me back, didnt havr time to get pics plus it was dark
plans for today.
consume 215
anti axle wrap device
mount fuel pump & regulator
mount fuel, coolant, and air filters.
finish miscellaneous odds and ends in the engine compartment.
rob 01 SD of air compressor and tank.
install 2 starter solenoids( weld a plate to mount them)
install hood and metal work the inside and out.
fuel line , radiator, and some little other crap ordered.
started today off with a broken main water pipe;Sweet
it was awesome!
finished the frenched in disengage lever.
i now have a plan with the light bar!
drill 2" holes in the bumper and mount the bar behind it.
more to come on this...
finished the anti axle wrap device, sorta, still need to come up with a clean bolt in mount for the xmember.
final weld it after i get the rearend out of the truck.
take a break real quick and get back to it!
The start of fender covers
Will be a place to mount stuff and lined with some brushed SS
F350camper
BOOST!
very nice, that will really make things look tidy. Are making them semi-removable? Or pretty much in to stay?
Undecided. Gonna finish the pass side, tach em in and look it over till I decide.
Don't wanna weld em in and findout the fender won't come off
tke395
