'86 Extended cab project thread
BlindAmbition
SoCal
Figured out the intake piping, took way longer than I thought. Ended up taking a piece of aluminum, bending it by hand to make a mockup of the angles, and ordering the correct bits which arrived today.
2" - 3" 45*
3" cast aluminum 90
3" coupler
BlindAmbition
SoCal
Worked on the intercooler reservoir today. It's an old 3.4 gallon propane tank from a VW Westfalia van, was going to use it for my air tank but I don't trust it to hold the pressure. TIG welded some steel for the first time today on it, pretty happy with how it came out for a first try. First pipe thread I added was too low once I figured out the exact mount, so I turned it into the drain and welded a different bung to feed the intercooler pump.
Saw a bit of advice on another thread to run different color coolant for the intercooler so as not to confuse where a leak is coming from.
Will finish mounting and then start plumbing.
Tank → pump → radiator → intercooler → back to tank
BlindAmbition
SoCal
Mounted a smaller reservoir to be the fill spot for the system. Will likely need to lift it when filling to get the air bubbles out since I cannot mount it higher than the intercooler. Fuel heater and the motorguard final fuel filter are also mounted. Still need to trim the heater bracket and give it some paint.
The_Josh_Bear
Western WA
What's the plan for the oil line coming out of the turbo? It's dead-headed from the factory, just a spot for the pressure sender. Or is that two feed lines coming in? I've never seen it either way.
BlindAmbition
SoCal
Oil line is plumbed. 1/8 npt on the block to 4an fitting and then a 24" line. Oil block on turbo has two feeds, second feed is 4an as well to my oil gauge
BlindAmbition
SoCal
Finished the oil bypass setup, got the coolant/windshield reservoir mounted, mounted the fuel regulator setup, clocked the turbo and tightened it down, and installed a CCV/CDR adapter on the timing cover to prep for installing the Mann Provent 200.
Will work on installing intercooler reservoir and intercooler plumbing tomorrow.
Soon after that is creating my fuel filter/pump setup
Then starting the engine.
BlindAmbition
SoCal
Got the intercooler reservoir mounted. Will work on the pump and routing hoses next. 3.4 gallons is overkill but I don't think I'll get heat soak except on perhaps very long drives
BlindAmbition
SoCal
Shouldn't be much at all, if any really. The run is super short, something like an 1/8 of the distance for most air to air intercoolers that folks are successfully using. I'll likely have lower pressures overall by a small margin, like one or two psi, but much denser air. Given it is a 6.9 I like the lower pressure idea so I can hold off on studs until I get the ability/space to pull the engine and stud it.
BlindAmbition
SoCal
Finally found a 3.73 ratio SRW 2906 Dana 60 axle for less than a grand (I know they are cheaper elsewhere, I'm the great state of California).
Stalled on the intercooler reservoir, the tank leaked from a few spots, either my welding skills aren't awesome or using a random propane bottle from a 70s VW camper van wasn't the best idea. Or both.
Anyways, will start work on the front axle swap soon while keeping an eye out for a ZF5 4x4 mid ratio trans. Have the close ratio already but seems like gear ratios might be better on the S5-47.
RustyNail351
