TBigLug
I Miss U Baby Girl
Oh, and the noise. I haven't been able to get behind the sound of a 6.5. The 6.9's are a little better but I gotta lean towards the CTD for true diesel sound.
The 6.5 is a good engine. And the 93 is either the last year for all mechanically controled or the second to the last year. Which is good . The elecronic ones suck
As for the electronic 6.5 I will say I LOVED that aspect of mine. It was not as simple as mechanical injection, but that doesn't make it bad.
Any electronically injected 6.5 MUST (I can't say must enough) have a PMD (pump mounted driver) isolator. This device drives the injector pump and when the motor gets hot the PMD overheats due to the fact it is placed directly onto the IP in the engine valley and has no way to disperse heat. I put mine behind the front bumper and it turned my truck into a whole different animal. I would put money on this being 98% of the reason the electronic models have a bad reputation![]()
The electronic 6.5's sound like a mini D-max with a strait pipe and that is so much sexier than the Buuuurrrrraaaa KA KA KA KA KA KA KA KA my 7.3 makes when wound up![]()
Can't you just put a heat sink on the PMD like on a computer processor, also with a small fan on it (they run at 12v) as well? I definitely know they should be moved away from the stock position mounted in the oven to a cooler place, but a fan would be a help no matter what.
Here's an interesting question that has been touched on, but not directly asked...
How do YOU use your truck?
Maxing out the bed capacity? Not often but it has happened.
Towing 10k? About 12 to 20 times a summer depending on how many pulls and plow days we go to. Trailer + 4 Belgians + Harness/ Equipment~ 14K. Usually hauling between an hour and 3 hours away (depending on venue).
Driving empty to work every day and dreaming of throwing something in the bed? Driving daily to work, yes, dreaming of throwing something in the bed, not so much.
How many miles a month do you slap on her? ~1,000 miles
Something else?
And...Why does your buddy want to trade? What is it about your ford he likes? Pretty much just the fact that it's a Ford. His Chevy isn't in nearly as good of shape (body and interior wise) as my truck. I wish I had a picture of his truck. The swap isn't as much one sided as it sounds reading back through the list. His truck definiteyl has it's quirks. I just don't think I want to give up the ole' **** quite yet. Especially since now it's finally ALMOST where I want it to be. Basically, my truck is truely a DO-IT-ALL machine. It has to haul my 14k trailers, drive me empty to work, get loaded with scrap to the yard, get to MO and back to visit family and every little knock around chore the farm has. Truth is the only thing I wish my truck had that it doesn't is 4x4. If his had it, my old girl woulda already been gone.![]()
