86 6.9 keep leaking out the left rear injector return
Azidiguy
Arizona
Hello
New here but not to idis but im having a problem with the return cap on the left rear injector keeps leaking despite multiple caps and o rings.
Thoughts on this done lots of these never had this issue.
Thanks in advancep
String of bad luck with parts, or maybe a damaged injector.
captain720
Washington
I’ve got one that sometimes weeps a little, after probably 6 brands of o rings I gave up. If anyone has a great idea let me know
WrenchWhore
Lake Havasu City
My gut says check the cap itself. I just measured some of my original Ford return line caps and all measured about .631" on the inside. I bought a return line kit off amazon that was "German made" and the caps that have a 90 degree turn in the back cylinders (7 and 8) were oversized by more than .010". The straight caps in the middle cylinders were oversized but not bad enough to case a leak. If it isn't an oversized return line cap then I'd look at the bottom of the hard line to make sure it hasn't split. It's unlikely but it happens.
captain720
Washington
This could be my problem, although mine are classic diesel designs.
Brian VT
Maine, USA
Many here have run into this problem. Have you tried different brands of o-rings?
The ones that came with my injectors and caps weren't sealing well so I went and got a box of assorted from Harbor Freight and those happened to work great on my injectors & caps. Cost me $10 to use 8 of these o-rings but they did the job on mine. Worth a try?
Others have also had success with buying them from McMaster-Carr.
Azidiguy
Arizona
Line hasnt split it eas leak free for 20 miles when first done. Got a whole new set different brand too so we will see if that helps
This could be part of the under carriage rust prevention built into these trucks. Especially since it's consistent and at the back of the engine. The diesel will mix with the oil that's mysteriously leaking back there and the thinning will allow it to coat the whole bottom of the truck more efficiently. It's genius really, how this was designed.
That was my problem. Did the return lines 3 times with different brand O-rings before I finally caught what was happening. I installed my old caps and have had zero issues ever since.
I've discovered that the caps that come off are best myself. I mean really, how can they wear out just don't break them when you take them off.
Azidiguy
Arizona
This is true its huge step in rust prevention lol
WrenchWhore
Lake Havasu City
I suppose the heat gets to them like all plastic over time. I just keep spares with me when I go on long road trips just incase. I've been very lucky to say the least with my 600 mile road trips.
