lmarcucci7
Hi everyone, Having trouble with my 92 F350 IDI 7.3
The problem is that when I try to start it, I hear a loud click(A solenoid click)
Anyway, Here's what I tried. I can't figure it out.
-Changed the starter/starter solenoid(No change, except a slow crank(Could have been from weak
batteries) the very first time I tried after letting the truck sit for 6 months prior to starter change)
-Bypassed Starter Relay on passenger fender. Still hear the same click
-Tried starting the truck in neutral to test gear position sensor. Same click.
-Tested the old starter outside of the car by hooking the ground from another battery to the starter body, then positive to the starter positive. Spun fine.
The starter I got was from a junkyard, but it had been tested before.
Thanks for any ideas/suggestions to check!
