mexicanjoe
Mine leaks a quart every 500 miles, and I dont charge my employer for seal coating the parking lot with 15w40 Rotella!
!I usually order it online, but have noticed local auto parts stores are starting to carry it.So the Liqui Moly Diesel Purge.....Where do you buy it?
I see how using it to run thru the IP & injectors, thru the intake & return fuel , I got that idea. But do you run some of it in the oil to hopefully unstick rings?
I don't know for sure, but here's my take on it. First, remember that we're talking about dealing with the government here. It's a government agency that does the testing to enforce government rules. My feelings is that they're looking for signs of non taxed fuel being used. We all know that it's red. All they're looking for is a reddish tint. If they find it, you'll be charged with running fuel that hasn't had road taxes paid on it. I'd bet money that it would be up to you to prove that it's actually fuel out of a pump and had those taxes paid. It would be an uphill battle at the least. All the government wants is to get your tax money. They don't care about testing to see what's in your fuel. That would be how they pull people over and that person leaves with a fine. It would take time and money to test every sample of fuel that they pull, which the government doesn't want to spend. They only want quick, easy money and that's the fine. You'd have to leave your vehicle parked until that test came back negative and none of us want that. That's why I won't put anything that's red in my tanks. Right or wrong, I still won't take the chance.Even if DOT does dip your tank don't they still have to test it?
Well I was poking round on internet & found some Liqui Moly Diesel Purge here on EBAY:I usually order it online, but have noticed local auto parts stores are starting to carry it.
I have never used it on my IDI, only on my ALH TDI’s (2003 VW)Well I was poking round on internet & found some Liqui Moly Diesel Purge here on EBAY:
Diesel Purge-Liqui Moly | eBay
Explore a wide range of our Diesel Purge-Liqui Moly selection. Find top brands, exclusive offers, and unbeatable prices on eBay. Shop now for fast shipping and easy returns!www.ebay.com
So @Cant Write & you others that have tried it, have you noticed any difference afterwards using it on our IDI's?
Yes it certainly could.is there a path for it to feed oil through the turbo and the intake?
Sounds like my 91… only 40k miles, but all the idle hours…if I were a betting man, Id wager the cylinder walls are wiped mirror smooth from excessive idle hours. Pretty common in old diesels, especially in cold climates or ambulance use.
