Okumaguru
I traded it for a 1988 F-250 4X4. The truck came out factory with a 7.3 but it had problems so they put a 6.9 diesel in it. They were in the process of installing a new front timing seal in it when the guys dad had a heart attack so that is how I traded for it. It needs the timing cover seal installed, radiator, belts, etc installed.
I put the harmonic balancer on it and tried to start it yesterday. They told me that the engine had been ran out of fuel so the first thing I did was to loosen the fuel lines at the injectors, then crank it over for a few seconds, wait, then crank it more until the nuts were starting to get wet. I then re tightened them and tried to start it. When it wouldn't even hit I squirted starting fluid into the air intake and it still wouldn't hit. I then poured a little diesel directly into the air intake. It first sounded like they normally do when you use to much starting fluid, then it sounded like it might have hit once or twice but then wouldn't start.
I'm not even certain it is hooked up correctly although I expect it is. I looked thru my Chilton's manual this morning but it really didn't have much information on diesel's so any suggestions would be greatly appreciated. I don't know exactly what should have voltage and how much voltage there should be on a diesel.
Thanks in advance.
Tim
Thanks in advance.
Tim
