TBigLug
I Miss U Baby Girl
I've got a couple questions and they all seem to tie in one way or another to the vacuum system so I thought I'd group them all here.
My cruise control and vent selector switch are currently non-op. I traced the supply line from the vacuum pump and came to this fitting.
A & B I believe are vacuum supply to the cruise control.
C is the supply to the brake booster.
D is the supply hose from the vacuum pump.
F was uncapped when I found it so I cut a piece of hose off of E and stuck a bolt in it to cap it off.
E I believe is the vacuum supply to the vent controls.
After I capped the piece off, my cruise and vent control still didn't work though I did test the hose at the cruise and was now getting good vacuum. So, back under the hood. I found the piece below with a hose dangling that looked just long enough to reach the fitting.
What is A?
I hooked it back up and got no change in cruise or vent selector.
Am I correct that:
A is the vacuum supply going into the vent selector.
B is the vacuum supply to the vacuum canister for the vent controls.
C is the vacuum canister for the heater controls.
D is some kind of regulator for the vacuum supply.
E is the vacuum supply coming from the fitting.
As far as the cruise goes...
A is the vacuum canister for the cruise control.
B is the first supply hose coming form the fitting.
C is the vacuum supply from the canister to the cruise controlitself.
D is some vacuum hose going from one part of the cruise control to another. What's it do?
E is the second vacuum supply coming from the fitting.
F I believe is the cable that actually adjusts the throttle to speed you up.
Looking at the injector pump...
A is the end of the cable coming from the cruise control.
B is I have no idea. Anybody know what these hoses are for?
C is a mystery to me. What is this plug for?
D does it look like my pump is leaking? It's wet under there but no puddles. What's it look like to you guys?
Unrelated to the vacuum, but still a curiosity for me..
Where does A bolt down?
Sorry about all the pics but what do you guys think? Anything look out of whack? Am I way off base on what I think any of this stuff is? Any ideas as to hy I have no cruise or vent selector operation? It's stuck on vent and that does me no good when I need to defrost my windshield on these cold MI mornings.
Thanks guys (and gals).
What is A?
Am I correct that:
