6.9/7.3idi air to water intercooler. Marine injection pump, etc.
dansvan
Hello all. I have an air to water intercooler off of a marine 7.3. Mounts directly to the intake. Obviously some adaptation required. Also have the belt driven water pump and brackets to circulate the water. Add a small radiator in front and you're set. 500$ plus shipping.
Also have the 275hp rating injection pump. I have never heard this engine run, had a bad head gasket. Pump spins as it should. 500$
Also have all the water cooled manifolds, turbo, misc coolers, etc. Shoot me a pm or text me at 907-351-579zero.
Buyer pays shipping.
dansvan
I have two of these marine 7.3 idi's. One is sitting here 100% complete. Have a full shop manual with all specs and systems, and full control panel/gauges and wiring.
FarmerFrank
Blairsville, Pa
Anyone else notice the pump linkage is backwards? No advance plunger and linkage on the passenger side like a truck.
If I still had an Idi truck I would be putting that after cooler on for sure.
problem with that cooler is you cant run a stock turbo, unless you buy the marine turbo.
thinking these engines were in a cutty cabin, which leaves a lot more room.
if I was made of money, id be buying this complete set up.
then I can run bravo 1 drives instead of the bravo X drives that are 6k a piece.
but I believe these engines were bolted to velvet drives
id be really interested in seeing the water logs and heat exchanger for this...
dansvan
Here's a few more pics. These engine were not run in tandem. One is the original, the other was shipped up here as the replacement. I also have a full manual with all specs and all repair operations for the various systems. Came with full wiring cables from engine to complete instrumentation dash panel.
dansvan
dansvan
Make an offer on any and all of this. Worst I can do is say no.
Interesting pump. I saw those subtle differences. might be interesting to buy the pump. Send it to Mel. Test it just to see what it is capable of. Then take it apart and have a look see at what the mystry is all bout.
tke395
