kas83
With the moose pump he lost power, but got more boost. We can only assume that this is because he was out of his turbos map. With a DT466 or powerstroke turbo he might have made more power with the same internals he has now.
With any turbo that has a more efficient map and will allow good air to around 20 psi of boost, he WILL make more power. With a better flowing topend, in addition to the better turbo, he WILL make power. Cooler, denser air will always make more power, and HELPS with economy and reliability as well. Less heat equals less stresses on internal parts, as there is only so much cooling that can be down with oil.
Why is everyone hung up on a PSD or DT466 turbo? The PSD turbo will be on the low side of it's map at 15 or so psi, and that isn't helping anything either. A DT turbo, depending on original app, will either be super hard to spool, or also be on the low side of the map.
If someone can give me some airflow ratings on a Banks, ATS or Hypermax, I will try to find the map on a PSD or DT charger, and then compare it to what I've been contemplating running.
