6.0 boost pressures
Have an 03 at work for a service truck, randomly looses power and rolls tons of coal. what is boost on these so I can order the right gauge,
thanks
Russ
Yep agreed.
I believe the stock max is ~30lbs. I think it will set a Check Engine Light at 32PSI. I don't currently have a boost gauge on my 6.0
Ford428CJ
FE Freak!
Klamath Falls, Oregon
Sounds right, 26~28lbs.... Depending on mods.... You can easy run over 30lbs with a stock turbo BUT I dont recommend it. Keep it under 30... JMHO
tbirdfiend281
Eldersburg/Sykesville, MD
The stock turbo unloaded sees right around 24 pounds of boost threw the computer signal. I have seen 28, but only on trucks with a bit of intake and exhaust work. The turbo does just fine above 30psi all day long, though I would keep it under 35 pounds.
NJKen
is a daddy!
Central NJ
My fat F550 (16,000lb all day every day) will put the gage to 30lbs going up a mountain. Thats the highest I have ever seen it go.
Ken
WVJR
West Virginia / Arizona
I run a stock 2008 F350 6.4L and the gauge on the dash goes up to 40 lbs of boost... not to say it actually throws that much boost.
tbirdfiend281
the 6.4 is completely different, having 2 turbos, and the international maxxforce 7 (your 6.4) at 300hp will see every bit of 36 pounds, so I could imagine the fords could see 40.
oregon96psd
Kuna, ID
So my 06 f550 service truck may have something wrong with it then? It's weighed 20-22k pounds since it got it a year ago, and I've never seen more than 20 lbs out of it. I even went to and from North Dakota with my trailer at a combined weight of 28,460 lbs, and on the passes it held right at 20 lbs.
oregon96psd
Kuna, ID
Sooooo.....should I start looking for leaks, bad turbo, bad guage, cash for clunkers cocktail?
olsen726
