4" exhaust kits
international
Drownin' in diesel
Mt. Vernon, Ohio
sounds like crap!
I have a 3" straight pipe coming from the Y pipe from the headers, no turbo, and it sounds terrible! It sounds like a loud gasser!:puke:I wonder if a turbo will help the sound? 2500-3000 rpm is deafening. I'm dissapointed. -cuss
91f2504x4
KY
A turbo will act as somewhat of a muffler to break up the exhaust noise, and it will really add a nice whistle when you load it.
flareside_thun
Reviving The General Tao
Tavares, Florida
So what is the ideal pipe size for a good deep tone and power?I do understand that a tip makes a difference in tone as well.......I want a deep tone but don't want to lose any power....if anything gain some low end.
kpj
Finland
Yep turbo will quiet down exhaust noises quite a bit. My brother has a E-350 N/A with one muffler and it's still way more noisier than mine with straight exhaust....
1994IDI
Destin, FL
Can anyone tell me if the WLK 54387 tailpipe exits at a 45 degree or does it make a full 90 like the factory tailpipe? Pictures would be great.
razorback
branson, mo
i ordered some stuff yesterday for my exhaust, i ordered a 3.5-4 transition, a 90 short radius 90 in 4 inch and a 45. i will order the 4 inch tubing later. i want to eventually go to a 5inch single stack. but right now i have to fab up stuff for my new turbo.
i forgot to mention that my turbo has a 3.5 inch vband.
Mat J
Way down south
Jupiter, FL
so everyone without a turbo what are you doing with the stock y pipe? I want to go 4" but what do you do to either transition from the little y pipe?
international
Drownin' in diesel
Mt. Vernon, Ohio
Cut the Y far enough up so you can weld on the 3" or 4". You will have to bend the pipes a bit to get a good fit. I don't see much sense in going from both manifolds to a Y pipe that is only 2 1/2" then bumping back up to 3" or 4".
Diesel JD
Gainesville, FL
Yeah a straight pipe or even a free flowing muffler IDI sounds an awful lot like a BBL gasser when loaded down at higher rpms. Definitely sounds much better with the turbo and you are not getting all you can out of your turbo mod if you have anything close to a factory exhaust on there. I had 3" all the way back through a free flowing muffler and when I cut all that crap out and went with the 4" straight pipe MAN what a difference. Not that much in boost unless you really get on it but much more responsive by the old butt-o-meter. Better whistle from the turbo and less "cackle" a V8 is always going to sound like that some, really mine sounds a lot like an old diesel log truck I think.
funnyman06
Coventry, RI
Maybe now would be a good time to upload pictures? Anyone interested?
Edit:
Images
If anyone wants anything different ill post...
dyoung14
Is getting worn out
spencer,tn
Edit:
Images
take pics of your hole exaust system im interested, and you have a nice truck;Sweet
funnyman06
Coventry, RI
I have a ton of pics...
I still need to get an updated y-pipe so i can run 3inch to the muffler... But it helped a lot just getting rid of the stock muffler.
dyoung14
Is getting worn out
spencer,tn
yea stovk muffler is very restrictive
RangerDanger
