PnrFab
first made a post several months back on another site (just found out about this one ) anyway here is a link to my first post first post about this truck since then i check the oil, had oil (black), installed some batteries, disconnected the hose that runs from the tanks to the fuel pump into a 5 gallon tank with fresh diesel and fleetguard additive in it, dropped the steering column (no ignition) and pushed the lever that runs along the top into the "ON" position to power glow plugs. long story short got it running. now what would be the next thing i do? it was decommissioned for a reason (unless security wanted a new truck and just made a reason) someone around work said something like bad compression but not really sure. would that be the next thing i do, before dumping allot of money into her (oil change, hoses, belts, etc...) until i find its really in good shape...sorry for the long post but any help is really appreciated...
one more thing, radiator was bone dry (filled with water), and now i just found out about the cavitation. truck ran for less then 10 mins untill i pulled the fuel line out of tank and starved it. also noticed the tach was not working is that due to not having a ignition and just sliding the bar on steering column forward?
-josh
-josh
