is it a factory turbo or an aftermarket turbo????if its factory the 5 speed is your problem.the turbo IDI only came with an auto trans.if it is a factory turbo truck you need to check all the wireing for the tranny.something isnt hooked up right.i did a 5 speed conversion on my 94 turbo truck and my cruise still worksIts a 5 speed
He is right, all electronic, mine was not working because of the clutch depression switch, will your truck start without mashing in on the clutch.
There are two different switchs and feeds coming from the clutch switch.
