Hey guys. I'm lookin at a 77' F-350 super cab Camper Special
. Its got a 460/c6. I was thinkin if i got it, swappin that for a 6.9l/zf5. What would i need to do? I figure id have to swap these as well:
Gear selector from steering colum,
gear indicator from dash,
Engine mounts,
Tranny mounts,
Fuel tanks & Lines.
Am i missing anything?
There is no gear indicator on the dash, it's on the steering column.
Fuel tanks are fine, just clean them out.
You will have to run a return line back to the tanks, just braze a nipple onto the filler neck.
Tranny mount, you should be fine, use the stock zf mount, might have to move the crossmember.
Motor mounts, can't help you there, mines 4x4, different setup.
Body lift only if your going with a turbo, clearance for the downpipe.
Some have done the swap with the stock radiator and say they have no cooling problems, I went with the super cool rad (largest you can get for this year truck).
Throttle cable, I fabbed up some brackets so I could use an 85 cable.
I'm probably forgetting a bunch of things but this should give you a good idea what's involved.
Dennis
