This little guy ?
That's the *******!
This little guy ?
This little guy ?
That's the *******!
the booze is what makes the whole emergency kit work!
Not only is the OD smaller, but so is the ID.This fitting is both useless and extremely valuable at the same time.. As we are finding out. I purchased the van line for just this issue but. Seems my van line was of a smaller tube outside diameter and my clamp for pulse timing would not fit. I will need to re examine this further cause I sure don't like useless "things" on my engine.. Like a fuel heater that really never worked or proven needed... Even in the extreme cold slat belt areas.
just as a side note.
if you switch 6.9 lines in place of 7.3, you must go all or nothing. there is a difference in the line length.
ideally would be to find a van 7.3 #1 line. if not found, the entire set of lines must be changed out or a firing imbalance will arise.
I guess by indicating there's spare booze back there also serves as an example that I probably won't successfully fix anything and will wind up drinking instead, but oh well lol.. Can't win them all
