bbjordan
Snow Monkey
Well, I can't really argue with that now can I?
That definitely seems to be an issue with high(er) valve lift and inadequate valve head recession relative to deck. Sorry to learn about your misfortune. That really sucks. It's not called the school of hard knocks for nothing.
laserjock's problem looks more like valve float though, as it occurs at higher (3000 ) rpm.
It could be that piston to valve clearance is running at the ragged edge, but the higher rpm pushes it over the edge.
I'm just thinking out loud. The input of you and others that have "been there, done that" is so valuable. I, for one, really appreciate that you can share your misfortune so that others may benefit from your experience.
I suppose we'll just have to wait for the autopsy. I'd really like to know what the valve spring pressure #s are on Mike's engine and what the recommendations are for the TYP4 cam. @typ4
