ZF5 reverse - repair time!
Macrobb
North Idaho
I'm playing around with a '93 ZF S5-42 which... won't go into reverse. Just plain grinds.
However... If I pull the shifter off the top, and manually stick it into gear using a couple of screwdrivers to lever the "socket" piece... it'll go and stay in reverse.
It's like it won't go quite far enough with the shift lever. All other gears work fine.
Any ideas on what might be worn out or missing to cause this?
(Note: I've got no history on this trans. It was found in a JY on top of a stack of junk, missing the shifter. Got it really cheap because of that).
ifrythings
BC
Sounds like your blocker ring is wore out and the synchro sleeve and gear are wore down.
I had the problem of sometimes grinding going into reverse and popping out of reverse.
I replaced the 5-R synco assembly and reverse gear to fix it.
Old reverse gear with blocker ring
Old reverse gear with ground down teeth
Old 5-R synchro slider showing the ground down teeth on the reverse side
New reverse gear
New 5-R synchro slide
BlackNoma
Sweeny, TX
mine grinds going into reverse unless I put it into a gear first and then go to reverse. or if it's the first gear I put it in after I start the truck. kinda weird, but no big deal.
keep us updated on what you do to fix it.
hesutton
The Anti-Anderson
Bowling Green, KY
I had the same issue as pictured above on 460 ZF5 I swapped into the 6.9 crew cab. Had to replace the 5/R synchro and slider. No issues since.
Heath
Macrobb
North Idaho
So... good and bad news. First off, I ended up taking the shifter and machining a small chamfer on the copper ring where it would limit the travel of the shifter lever itself. This got me a few extra thou of shifter 'throw'... Didn't work.
Then I pulled the top off(that piece just under the shifter, where the 5th/reverse lockout is), and ground off just a bit of the round 'bit' on the upper left, which the 5/r lockout slider piece normally is - again, to allow the shifter to go just a hair further forward.
This... worked! Somewhat... it's still janky. But it did go into reverse.
We took a test drive, and aside from something inside the trans(probably the 5/r slider) bouncing back and forth and knocking off something... it did drive.
However, it's coming apart, obviously. All the synchros are pretty toasted, too...
Chuckmeister
Coopers Mills, Maine
All of the above. My '89 F 250 has had that problem since I bought it and I have been keeping my fingers crossed. Once it's in, its in. Most of the time I can keep it from grinding by"popping" it into reverse. The momentum seems to carry it beyond the slop or wear. Putting it in an other gear first seems to help too. Gets the gears stopped so nothing slows up the momentum of shifting. I know I'm going to have to deal with it eventually, but I haven't seen it get worse over the 5 years I have had it. Hope this helps someone like me who just wants to have a usable work truck.
Nathan Uskoski
Squamish, BC
Can you please bench test the transmission after rebuilding it. I just finished one and though I may as well bench test it. It shifts great but there is a clicking or popping noise. I took it apart and reshimmed the counter shaft. It is noisy and I am not sure what it is excepted.
Macrobb
North Idaho
I'll let you guys know if/when we do something with the trans - for now, we found an '87-91 460 zf5 in a JY last weekend for $100, pulled that, drilled it out and dropped it in earlier today(My friend and I can now pull and replace a ZF5 in an OBS in about 3 hours... getting faster at it!).
Found a little glitch - the '97 PSD we put this trans in has a SMF, and the very edge of the pressure plate interfered with the little support rib on the inside of the bellhousing... by about .010". We figured this out by the horrible clicking noise on first startup. I decided to just run it and call it good, and it 'self-machined' some relief within a couple of minutes, and runs great now!
Tyler9828
