Zf5 lost clutch pedal
Waystro
No Class
South Texas
Clutch pedal has been getting softer drove it yesterday and barely had enough pedal to shift. My replacement slave/master assembly from rock auto came in today. Put it in and now have no pedal at all straight to the floor it was supposed to be a pre bled unit. Took it back out and bled it but still can’t get truck into gear. Any ideas?
If the fork is definitely on the throw out bearing and all that stuff is in good shape..... itll come down to making sure its bled..... is the pedal rod bushing good?..... is the push rod on the slave cylinder in place correctly?...... did the new slave cylinder come with a new push rod?..... if so, is it the right length?....... just throwing out ideas.....
Rustmaster
