So got the transmission back, and I cleaned it up more today, I also drained it.
The oil was a darker colour of which was deep red not clear red. I did not see any chuncks, not even much in the way of small debri. it was quite good actually. Once fully drained, I reached in and felt all around best I could in the bottom and did not come out with any metal so to speak of, I was impressed.
So I cleaned off the gasket surface, got a thin bead of hi temp RTV, I hate doing this but it's what I had to do, until I purchase a NEW gasket and sealed up the case.
I then removed the fill plug, and poured in fresh new ATF into the transmission. I spun the main shaft and carefully moved around gears and then added more till it seeped out. Now I'm set to install the transmission
I found more markings on this trans too, like clearances or something so I'm not sure if it is an original, a rebuilt, or a wrecker replacement. All I know is it was quite clean inside!
So without further ado....
So there we have a cleaned and repaired transmission, however he did not plate it as I had hoped. If it doesn't hold I'm told it will be taken care of. !!!
Thanks for lookin
Al
