thill
93, f 350 idi. manual trans. 10" arbortech chipper body, 4 wd, borg warner transfer case. I went to flush the transfer case this morning. Way more fluid came out then I was able to get back in. Using atf. Do the tranny and transfer case share fluid? Cuz when I took out the fill plug, even before the drain plug was open, fluid started pouring out. Tranny is mounted above transfer case, so my thought was that trans fluid came out? Also is the zf 5 the only transmission that is a manual in these trucks? Thoughts? input? I plan on changing tranny fluid as well soon, but I need the truck this weekend and didn't have the time to do both, but know I'm worried.
