leswhitt
Well I finished the trip with no issues and am now in Buffalo, NY. I scaled the truck at one of my last stops and was at 25,400 lbs. Judging by the spare stuff that I tossed/gave away during the trip, I'd be that I was nearing 27K at some points during the trip.
MPG worked out to just under 7 for the majority of the trip and I definitely get better mpg on straight diesel than I do my WMO mix, probably right around .75 mpg better.
I was a bit worried in CO, I was pulled over by a CO State Trooper because in her words, "My truck was throwing black smoke like it was either a freight train or on fire". I thought maybe I had broken something but when I checked the GPS, I saw that I was at 9,000 ft....no wonder. The highest crest was 11,400 feet and it was a solid hour of 2nd gear at 7mph to even get to the top! Coal was definitely rolling then... When I got past Denver and back to a reasonable altitude the smoke cleared up and it was back to it's normal little puffs of white smoke at startup and idle.
Overall, the truck ran about 10K miles on this trip and burned approximately 600 gallons of WMO. I would've loved to have burned more but my supply ran out and I didn't have enough filtering time left to warrant collecting any more once I got to CO. Even while mobile, I found that settling was key to pull any water out of the oil and filtering was key to make sure that sludge didn't get through. I ran about 17% RUG to help with the settling and thought that was about right to make all the crap drop out. For filtering, I'm using two Fram 20 mic/10 mic oil filters followed by a Wix 6 micron filter. For the pump, I had a SBC pump that was aces on the first part of the trip and then crapped out. I finally bought a HF barrel pump in Las Vegas and that's been the best pump so far. to keep the arms from getting too sore, I'm going to either hook a gas or electric motor to it and aim for 100 RPM when I'm collection which should be @14 GPM. For filtering, I'll slow it down to about 25 RPM for a nice flow of 3.5 GPM.
That's about it, hopefully this info helps out the next guy...
