I went through oil filters too quick when I pump from the settle barrel to the centrifuge barrel. I just plugged another set of PH2825 filters at a new record of only 50 gallon of waste oil through it (or 25 gallons each filter).
I'm looking for different and better oil filters to replace the PH2825 and I found it quite difficult to find bigger ones with 3/4"-16 thread with NO BYPASS VALVE so I started to look for alternative thread size to get more oil filter options. I went to TSC today to look at what they have and I found that P1654A with 1"-12 thread is pretty much double in size physically of PH2825 and no bypass valve and it's a "hydraulic filter" so it do not have the anti-drain valve, which we don't need in this application anyway. It's rated to 25 micron which is well within my need.
While I am in the store, there's a filter right beside P1654A which is the P1653A which is nearly the same as the P1654A but rated to 10 micron. I think I'll like to replace the PH2825 filters on my centrifuge cart as they're 20 micron to run the P1653A for two reasons, they're bigger and filter more tightly at 10 micron before the oil will go into the 5 micron filter I have after the dual head filters.
Fram P1654A
Fram P1653A
Fram PH2825
The best part about running the P1654A filters is that I can get a pack of 6 shipped for only whoppin $17.xx which means $2.80-ish each, can't really get any cheaper than that
Cheap source for the P1654A
The obvious problem is how I'm going to attach the bigger filter on the filter head, which I found this converter on ebay to take care of this problem.
3/4"-16 Thread to 1"-12 Thread Converter
I bought ONE P1654A today at TSC (they only have one anyway) to cut open, and I have one extra PH2825 to cut open too, so I'll have something to compare before I make some purchases as I want to make sure it'll worth my money to make the change. I'll post some pic when I get them.
