1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Winter is comming test your Glow plugs.
Discussion in '6.9L IH & 7.3L IDI Diesels' started by reset2, Sep 11, 2018.
  1. reset2
    reset2 Full Access Member
    122
    73
    Jun 5, 2009
    Myersville MD USA
    After my truck got much slower starting this week (in Maryland). I had to put the glow plugs to the top of the list. When ever you glow plug controller times out very fast most likely a glow plug or several plugs are burnt open. My truck had three that burnt open and a couple weak ones. Put the best used ones back in and two new ones that I had on hand. 20180911_205506.jpg
    Four things you will need for this job.
    1. Some good used or new glow plugs.
    2. Can of copper high temp Never Seze.
    3. Top Side Creeper.
    4. Test wires to hook to battery and test the old glow plugs
    The test will be in the morning.
    F350camper, jwalterus and Thewespaul like this.
  2. jwalterus
    jwalterus Made in America
    2,503
    650
    Feb 11, 2010
    Minot, ND
    Why test? Up here a full set of 8 is an "annual maintenance item". LOL ;Poke
    Scooch, chillman88 and tbrumm like this.
  3. reset2
    122
    73
    Jun 5, 2009
    Myersville MD USA
    One of my faults ( or blessings) is that I like to see how things work. Before this truck I never seen a glow plug or completely understood how they did what they do. Also if a person keeps track they are a good indicator of what is happening in the engine, but by using used plugs the data could be misleading and I realize that.
    jwaltreus - do you change yours each year? Or do you change them when the controller tells you to. Just curious.
  4. jwalterus
    2,503
    650
    Feb 11, 2010
    Minot, ND
    Every year in Sept (I'll be doing them this weekend).
    Hard for the controller to tell me anything when it's been completely bypassed for years. LOL
    Change them, test the old ones, throw all the "still good" (generally 6-8) ones into a drawer in the shed.
    I give them away to a few buddies when they need a set, and use them when I pick up a truck to flip.
    My stash is currently down after a couple of sets being used this year, I doubt I have more than 20 GPs in the drawer right now......
  5. riphip
    riphip Supporting Member Supporting Member
    488
    94
    Nov 16, 2005
    Romans: 12-21 Memphis, TN.
    Make sure you have a new spare starter if starting is slow. They usually quit away from home & proper tools.
    IDIBRONCO likes this.
  6. Hydro-idi
    Hydro-idi Full Access Member
    2,262
    345
    Nov 8, 2011
    Lodi, California
    If you have to change your glowplugs every year, something is definitely wrong there.
    They will last years if your GPC is working properly. Push buttons are a good way to junk them quick.
    GP’s are very simple to test. If they glow, they are good. If they don’t, they are junk.
  7. steelheadguy
    steelheadguy Registered Idiot Supporting Member
    30
    292
    102
    Jan 23, 2016
    Southern Oregon
    I just do an ohm test on the multimeter. No battery needed and you dont need to remove the plugs.
  8. IDIBRONCO
    IDIBRONCO IDIBRONCO
    2,548
    1,234
    Yes, but he said that he installs a new set every year. He throws the good ones in a drawer to hold on to. I don't see this as he needs all 8 every year, just some. This is probably a better safe than sorry thing.
  9. chillman88
    chillman88 Supporting Member Supporting Member
    2,034
    1,118
    Feb 22, 2017
    Central NY
    If it got as cold here as it does in Minot, I'd be changing them every year too! I'd hate to be stuck because the truck won't start in that cold!
    jwalterus, bbjordan and IDIBRONCO like this.
  10. BrassBandit
    BrassBandit Registered User
    26
    6
    Aug 30, 2018
    Bonnyville AB
    Changing glow plugs every year sounds crazy to me. I put 400 000 + km on my 02 7.3 before having to do glow plugs and I live in northern Alberta. Truck would fire no problem at -30 any colder and it had to be plugged in. I use my welder as a Canary, if it won't start nothing I own will.
  11. Macrobb
    Macrobb Full Access Member
    1,918
    854
    Jun 12, 2016
    North Idaho
    When the controller short cycles, I test and replace my glow plugs by pulling each lead, then doing a "spark test" - just use a piece of wire with one end connected to B+, and touch your GP terminal with the other. No spark = bad. Weak spark(compared to others) - pull and double check(when applying 12v, the tip should be bright red within 10 seconds or so - compare to a new one).
    reset2 likes this.
  12. chris142
    chris142 Full Access Member
    2,599
    166
    Apr 15, 2012
    SoCal
    When my controler short cycles it means I need to clean where they plug onto the glowplugs. Had the same ones in since 2012.
  13. nelstomlinson
    nelstomlinson Full Access Member
    199
    71
    Oct 21, 2015
    Delta Junction AK
    I'm consistently reading about 0.2 Ohms on my plugs when I do that.
  14. saburai
    saburai Full Access Member
    1,194
    438
    Mar 15, 2016
    Pardon my ignorance, but what do you mean by short cycles?
  15. chris142
    2,599
    166
    Apr 15, 2012
    SoCal
    The light blinks and goes out instead of staying on 8 or so seconds.
    F350camper and saburai like this.
Share This Page
